hello.
please, can I use TOMZN TOB1Z-125 breaker in combination with Mega Fuses 125A between batteries (3x US3000C Pylontech) and Quattro 48/8000 + SmartSolar MPPT RS 450|100?
Cable is AWG 4. As it was packed with batteries.
thanks.
hello.
thanks.
Having both is not necessary. If you add too much joins and resistance to a battery setup is has adverse effects.
Most daisy link the Pylons and fuse only the cables going to the bus bar. And each battery has an on/off switch.
You do need a few more US3000 batteries for an 8kVa Victron to meet min spec. Ideally 5 in total.
30 People are following this question.
