Can someone tell me, why "limit charge voltage" doesn't work? But in the same time, current limit works well.
Cerbo GX is not connected to the battery.
![image-2022-12-07-221542764.png](/storage/attachments/44703-image-2022-12-07-221542764.png)
For "Limit managed battery charge voltage" I set max value: 56.6V
For "Limit managed battery charge current" I set max value: 35A
Are there some pitfalls?
I have the system:
- Victron MultiPlus 5000/48/70
- Cerbo GX
- LFP battery with I/O: 1x RS232 (RJ-11), 2x RS485 (RJ-45)
No CAN interface (RJ-45)
Like this one: https://www.xdbattery.com/512KWH-48V-lifepo4-Rack-Mounted-battery-module-309.html
