nesswill avatar image
nesswill asked
Adding a Marlec Rutland FM1803-2 Windcharger
I have an MPPT 450/100 & a Smart Shunt 500ah and 1300ah of Batties @ 48v.
I have DCVV enabled and DC monitoring on my GX Cerbo.
Is there any problems or issues anyone has come across by adding a wind turbine?
If you need any more info, please let me know.
Thanks Dave.
battery charging
jodi5d avatar image jodi5d commented ·
FM1803-2 Furlmatic Windcharger System Updated and more powerful! Technical Features The FM1803-2 Furlmatic Windcharger with its robust 3-bladed wind turbine is supplied with it's purpose designed controller. • New 3 bladed turbine design combines an efficient profile with a durable injection moulded construction. • The 3 phase generator has a very low torque enabling power generation to start from just 3m/s (<7mph) windspeed. • Rutland unique disc type brushless generator design has a high degree of inertia that keeps the turbine spinning between gusts of wind where other designs stop and...
bathnm avatar image
bathnm answered ·
I have a Rutland 1200 running on my boat without any issue. It will not integrate into the Victron eco-system and DVCC control. I do have a smart shunt on the negative output of the controller so that I can monitor the output from the generator. Make sure the controller can be configured with a Lithium charge profile.
nesswill avatar image nesswill commented ·
"I do have a smart shunt on the negative output of the controller so that I can monitor the output from the generator."
Me too, ok thanks for all the help.
I have just ordered the Turbine so it will be a few weeks be for i get it all setup.
Cheers, Dave.
anthony avatar image
anthony answered ·
Is this an on or off grid system? What is the brand and model of battery?
Hi thank you for taking the time to get back to me.
Off grid. (once completed)
x20 (will be x28 when complete) 12v 260ah Expedition Plus Agm Deep Cycle.
Thanks Dave.
