Frank avatar image
Frank asked
Adding a multiplus (charger only) to a complete system, how to protect lithium batteries
I have a system with victron lithium batteries + quattro + Ve.BMS.
For quicker charging i would like to add a multiplus (because i have one), set on charger only, without connecting it to the system with network cable and without using the 230v output.
Now I need to make sure that the mulitplus is connected to the charge disconnect from the VE.BMS, but how to do it? I tried to connect the remote connection to the charge disconnect, but that is not working. Can is use a battery protect or will this blow up the multiplus when activated? Is there another way?
MultiPlus Quattro Inverter ChargerLithium BatteryBMS
