Tried the recommended solutions nothing works. Smart 12/2000. Phone sees it can't connect doesn't recognise default pin or puk. Old phone is unusable.
No problems with mppt' just inverter. Driving me nuts any help appreciated
Hi
What does VictronConnect show when you reset the PIN code (using the PUK)?
Have you also tried to power cycle the product by disconnecting it from the battery for 5 minutes?
Kind regards,
Thiemo van Engele
Hi @SVCordelia
What you describe is not the PUK code. Unfortunately we manufactured a number of Smart Inverters that did not include the PUK code on the sticker. So I suspect that you have such a model. You can check this by looking at the serial number (the thing starting with HQ). The first 2 digits after HQ are the year of production. When the year is 19 or lower (so HQ19....), it probably does not have the PUK code on the sticker. In that case, you can contact your Victron Dealer as they have access to PUK recovery. When it is newer, there should be a sticker somewhere that clearly says "PUK: .....".
Kind regards,
Thiemo van Engelen
32 People are following this question.
