David avatar image
David asked
If the generator fails to start, can the Victron be setup to try again?
I have had occurrences where a generator failed to start the first time, usually due to cold temperatures. My only solution so far is to either go to the generator switch it from automatic to stop then back to automatic. The other way is to reboot the Cerbo.
Is there a way to have the Cerbo on not detecting the generator on ac1 input, turn off the generator relay then try a second or perhaps a third time looking for the power from the generator on ac1?
I have had this occur on a couple of my systems.
Thank you for your attention.
Dave
starting generator
