Cracker F avatar image
Cracker F asked
Solar Charger 100/20 interrupts charging
Hey,
I bought 2 mppts 100/20 and they are running in an ESS System. The PV Panels are directed nearly in the same direction, but sometimes they reduce the output to 0W for a while... (Left image at around 13:30). Second mppt on the right working without problem at this time.
I don't get any errors anywhere and the battery voltage seems to be good, so I don't get why this is happening. Both mppts are doning this, but not at the same time, and only about 2 times a week for about 30-60mins.
Thanks for any hint.
MPPT ControllersESSsolar
Thomas avatar image
Thomas answered ·
Hi Cracker,
can you check if it was really 0 Watt or a low value below 10 Watt?
There are similar things in the german section.
https://community.victronenergy.com/questions/158791/de-smartsolar-10020-tracker-hangt-bei-wechselnder.html
Thomas
Cracker F avatar image Cracker F commented ·
Yeah really 0 Watt. Thanks for the link.
