What does the Autotransformer do with the 120V side if the input on the 240V side is 120V?
It steps it up to 240V then center taps that coil for split phase 120/240V output.
From the datasheet:
Datasheet:
https://www.victronenergy.com/upload/documents/Datasheet-Autotransformer-32A-and-100A-EN.pdf
Unfortunately, I didn't completely understand your question.
If you had the two sources isolated and connected them individually, I believe you would get what you want.
32 People are following this question.
