brt-off avatar image
brt-off asked
TR Charge post on Multiplus Compact
I understand that this spade connector is for charging the starter battery.
To what settings is the output set to, and is it configurable?
I have a AGM battery connected to the device. My starter battery is an lead acid type. Is it ok to use the setup like this?
battery charging
wkirby avatar image
wkirby answered ·
That terminal is designed for a starter battery. The start battery needs to be the same Voltage as the main battery. 24V / 24V or 12V / 12V.
You cannot have a 12V starter battery with a 24V main battery for example.
Current is limited to about 4A
There are no configuration options for this.
brt-off answered ·
Both batteries are 12V and in a 12V system.
But can you charge lead-acid battery with the TR Charge and use the big charger posts for an AGM one?
derrick thomas avatar image derrick thomas commented ·
Yes is no problem.
brt-off answered ·
Anyone can answer this?
