andre12 avatar image
andre12 asked
Multiplus 2 and AC Thor
Hallo,
I have a Multiplus 2 with a AC Thor heating element,
I wish to have the Temp. Reading 4 Sensors of the AC Thor showing up on the dashboard from the multiplus and also Sent the data via Node red to the KNX System
Whats the Best and easyst way to doo that
Bye André
Multiplus-IIAC PV Coupling
Mark avatar image
Mark answered ·
You can communicate with a MyPV AC Tror unit via Modbus TCP or HTTP. Contact MyPV and ask for the API document.
You can use NodeRED to communicate with the MyPV AC Tror unit via either method, but I have had more success using the HTTP option.
Note that some communication functionality is linked to the FW level in your MyPV AC Tror unit, and you may need to contact MyPV to help perform certain FW updates.
