does anyone know, what is the total capacitance (in nF or μF) of the capacitors on the MPPT 450|80 input of Multi RS Solar, or where can I find it?
Thanks.
Jakub
No answer? I thought that people from Victron, who have access to internal documentation, also read this forum.
The reason for the question is: I have a MPPT regulator dedicated to water heater (trapezoidal voltage only) which has the capability, once the water is heated, to pass the voltage from the PV panels directly to another MPPT, for which I'd like to use Victron Multi RS 450|80. However, there is a limitation on the total capacitance due to transient current peaks during the switching.
29 People are following this question.
