nir-fsight avatar image
nir-fsight asked
Send commands to Multi Plus (via CCGX) over API
Is there a way to use the SSH (or any other method) to send commands remotly to the CCGX (to set working points of Multi plus), instead of using MQTT / Modbus?
Thanks
Nir
Multiplus-IICCGX Color Control
pauldeg avatar image
pauldeg answered ·
@nir_fsight did you have any luck with this?
johanndo avatar image
johanndo answered ·
You could use the MK3 ve.bus HEX protocol used to configure and manage the inverters via ssh. If the things you want to change work already in VenusOS via the gui, you could directly read/write the dbus and let the victron drivers do their magic on the Quattro.
