matthew-sanan avatar image
matthew-sanan asked
Ethernet Panel Mount Adapter
Hi there,
I am busy designing a steel wall panel for a Victron system. I want to better manage cables and therefore I want to run them behind the panel and only have a short piece coming out from the equipment. For the VE Bus and VE can cables - could I use these RJ45 adapters to take the cables to the back of the panel in a neat manner? I also plan to parallel 3 Multiplus II's - and want to use the same methodology to connect them together.
Thanks
VE.BusVE.Canethernet
nickdb avatar image
nickdb answered ·
Patch panels add variables and opportunities to disrupt comms. Neatness is great but less complexity and stability is better. Rather don’t insert unnecessary parts in critical comms channels.
I do a lot of datacenter work and we avoid this stuff where possible and where they exist we spend way too much time diagnosing comms errors.
Keep the VE/CAN bus(s) clean.
What is VE.Bus?
