Lindsay avatar image
Lindsay asked
Beeping Multiplus-II (Three phase)
Can someone assist me please.
i have a 3phase connected, they all have been updated to the latest software. I'm using a Freedom Won 480V battery and the ACIN is not connected. However when i switch them on the the following happens:
First inverter- it switches on indicates inverter on, float, low battery, absorption and bulk LED switches on
Second inverter- it indicates the inverter is on and absorption LED then after a couple seconds it starts to beep
Third Inverter- it does the same as the second inverter
If anyone can any assistance and guidance would be recommended.
Multiplus-IIVEConfigure 33 phase
Alexandra avatar image
Alexandra answered ·
@Lindsay
Use victron connect when setting up the three phase initially. It sounds like (i saw your other post) as if the three phase is not set correctly. The other thing that can be a menace is the rj45s that connect all the units together (are they store bought or crimped)
See the walk through here.
Have you done a three phase before? And done the training on victron professional? Read the manual etc?
More on ve bus error 3 here.
Lindsay avatar image Lindsay commented ·
@Alexandra
Thank you for your response and yes I have done 3 phase before but not of this magnitude and we are using manufactured store bought rj45s, i did go through the manual and watched some installation videos on victron by victron.
