ssb avatar image
ssb asked
Multi Compact Solid Alarm Light
I have 2 Compact Multis 24/1600 in parallel, all working fine, now the slave has a solid red Alarm Light, I reconfiged the master to standalone and it is fine, Have tried disconnecting both AC and DC for a day or so- no change, VEconfig cant now detect the broken multi (tried different UTP cables and ports, to be clear it goes straight to solid alarm when turned on to either inverter or charger only- no other lights flash, was plugged into shore power at the time.
Any thoughts thanks??
multiplus in parallel
