jankoeppen avatar image
jankoeppen asked
Self-consumption on L1 only.
Hi, I have set up my system with 3x Multiplus, 1x MPPT250 and a BYD BBox Battery and use current transformers for measuring input current.
I have seen, that ESS does only work on L1.
In Backup Power (grid switched off) it works fine on all 3 phases from battery and MPPT.
I have configured ESS-Assistend for L1. Is there a trick to make it run in self consumption on all three phases?
Thanks for your support.
Jan
3 phase
derrick thomas avatar image
derrick thomas answered ·
Have you loaded ess assistant in all 3 multi's?
