delt127 avatar image
delt127 asked
BMV stuck at "bt200" after update
I installed the BMV-712 and it worked perfectly for two day while not using the Bluetooth feature. On day three I downloaded and installed the Victron Connect App on my Samsung S7. When I opened the app for the first time, it connected to the BMV-712 and informed me the BMV-712 needed to be updated. I agreed and the process began.
The installation got to 4-6%, then restarted, Next time it got to approximately 11% then restarted. This happened several more times, with the highest percentage being around 80%. Unfortunately, it eventually failed. I then looked at the BMV-712 display, and it read "bt200".
I then tried the following:
1. Try #1
a. Uninstalled Victron Connect App from Samsung S7
b. Reinstalled Victron Connect App onto Samsung S7
c. Connected to BMV-712, but no info on Victron Connect App or on BMV-712 (i.e. still read "bt200")
2. Try #2
b. Delete bluetooth data and cache from Samsung S7
c. Reinstalled Victron Connect App onto Samsung S7
d. Connected to BMV-712, but no info on Victron Connect App or on BMV-712 (i.e. still read "bt200")
3. Try #3 ... repeated Try #2 (after unplugging BMV-712 for 10 minutes)
4. Try #4
a. Turned off Bluetooth on Samsung S7
b. Installed Victron Connect App onto Apple iPad
5. Try #5
a. Uninstalled Victron Connect App from Apple iPad
b. Reinstalled Victron Connect App onto Apple iPad
6. Try #6 ... repeated Try #5 (after unplugging BMV-712 cable for 10 minutes)
7. Try #7 ... repeated Try #5 (after unplugging BMV-712 cable for 10 minutes AND resetting BMV-712 -- "Setup + Select" for 3 seconds)
8. Try #8
a. Turned off bluetooth on Apple iPad
b. Installed Victron Connect App on Macbook Pro
9. Try #9 ... repeated Try #8 (after unplugging BMV-712 cable for 10 minutes AND resetting BMV-712 -- "Setup + Select" for 3 seconds)
All attempts were within 2 feet of the BMV-712. I have wasted a lot of time trying to get this to work. I have no more ideas. Please help.
I have the Service Report files from all three methods (Samsung S7, Apple iPad, and Apple Macbook Pro) if needed.
BMV Battery Monitorfirmware update
Hi @delt127, I’m sorry that you are having such troubles. I’ll send you an email from our support desk, to figure this out.
Great that you have those service reports, it will help.
thomasel avatar image thomasel commented ·
Hi
Was this issue solved? i just had the exact same issue. have completed all the same steps to try and rectify the problem. Its trying to update to frimware 4.1. Gets to 6% restarts gets to 50% restarts then just fails
Hi all, to close the loop: this was due to a bug, introduced in VictronConnect v5.5.
Solved with todays v5.6 release. Thank you @delt127 for alerting and the nice punctual and complete reports and replies.
Victron BMV battery monitors product page
