Jonathan Manjoro avatar image
Jonathan Manjoro asked
3 x Quattro 8kVa, in a 3 phase supply with a 3 phase Automatic Generator
Hi there
Can someone please explain to me?
Basically, what is the best way to connect 3 x Victron Quattro inverters in a 3 phase home and integrate a 3 phase automatic generator, with a 30kWh Freedom won battery.
Also, is it possible to connect each one of the generator phases to each Quattro (1 phase per inverter)
Regards
Jonathan
3 phase
Kevin Windrem avatar image
Kevin Windrem answered ·
I suggest you read the following article from Victron:
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
This document also links to on-line training. Taking this training is highly recommended.
There is also a Victron article discussing generator start/stop control:
https://www.victronenergy.com/media/pg/Automatic_Generator_start-stop/en/which-relay-and-control-to-use-.html
Reaching out to a distributor or system integrator with knowledge of Victron inverter/chargers, multi-phase AC systems and generators is highly recommended as well for those who don't feel comfortable with designing such a system and/or performing the work safely.
