jeremias avatar image
jeremias asked
I have a question about RS Smart Solar inverter
Because the RS Smart Solar inverter has four mc4 inputs if they only have one mppt
It is necessary to use two positive and negative, or you can use only one input of negative and positive
If I have a (550 x 7 )solar panel with a current of 17A. How do I connect it?
inverter rs
Hi @Jeremias
The Inverter RS Smart Solar with a single tracker has the two positive and two negative PV inputs connected internally in parallel.
Therefore if you are within all other specifications (and it sounds like you are) then you can just use a single cable string and only one pair of the PV panel inputs, leaving the other pair empty.
