I have installed Multiplus-II 48/5000/70 in a three phase setup while I’m awaiting the delivery of the batteries. Now the AC out turns off and on periodically and I believe it’s because there’s no battery connected.
It is not designed to run without a battery and it is completely unsupported. Wait until your batteries arrive.
Bypass and switch off.
All Victron products are designed to run with a battery. If you need to do work on the battery you have to switch off the Victron system and switch the loads with a bypass switch directly to the grid.
33 People are following this question.
