RainerB avatar image
VRM Dashboard – Consumption overview is misleading for 1-phase ESS systems with activated Venus GX phase compensation
According to the „Last 24h/7d/30d“ diagrams in the VRM portal, someone could assume, that I use a lot of grid power. In fact, the meter of my grid company shows me a total consumption of only 4kWh(!) for the last full month (last 30 days).
Ok, it is true that a lot of power comes from one grid phase but that is nearly 100% compensated by the battery power on the other phase. I’m running a 1-phase ESS system with activated phase compensation. And exactly that is unfortunately not considered when calculating the above VRM diagrams and charts.
A test with my dishwasher (17:30 to 18:30) on phase L2 shows that nearly everything is compensated by the Multiplus 24/3000 on L1 (from battery).
Battery power (discharge) at the same time period
Consumption tab at the same time period
Here comes my issue - you can now see a lot of grid power usage, but in my opinion there should be nearly everything blue (battery usage).
For me, the above diagrams are quite worthless and it would be fine to have some VRM settings to change the behavior of the consumption calculations with activated phase compensation.
Any ideas how to improve this?
Best regards
Rainer
VRM
Has anyone running a system configuration like me and can confirm this (1-phase ESS system with GX phase compensation)? Or maybe does this VRM issue only affect my system?
Regards
Rainer
Mine to, at least now I know what’s the problem :-)
chris2 avatar image
chris2 answered ·
Hi, it seems that this issue still exists. I´m also facing wrong grid data with a new Multiplus-II installation, ESS, 1-phase, phase compensation.
1 comment Share
GeSt avatar image
GeSt answered ·
Hi @RainerB and @mvader,
I also wondered me about the behaviour. It's already a year ago, as I tried to describe it here: http://disq.us/p/1rbjikl.
So I would also be interested in a solution.
Kind regards
Gerhard
1 comment Share
Hi Gerhard,
I am "glad" that I am not the only one with this issue. Unfortunately it seems that this ESS phase compensation configuration is not used by so many people, though it is a very cool feature.
I hope Victron will improve this anyway.
Regards
Rainer
Hi @RainerB, thanks for this. This indeed sounds nice improvement. I'll keep it in mind for when we improve those energy calculation & attribution algorithms.
For now; its just what it is, I'm afraid.
2 comments Share
Hi mvader,
thank you for the information! At least I know that there is nothing wrong with my system settings.
Regards
I have the same configuration and I see the same issue. So I understand that a solution is not priorized, correct?
