anddittma avatar image
anddittma asked
SOC fall down over night
victron-soc-abfall-261022-0215uhr.jpgIn my system (Multiplus 2-48, GWL 4,8 kWh, Venus OS) falls des SOC overnight quickly from 75 % to 10 %, but no big consuption or feed was observed. Battery life was activated.
What can be the reason?
ESSLithium BatteryVenus OSSOC
peter-5 avatar image peter-5 commented ·
Did you find a solution?
I‘ve a similar problem with a MP and REC BMS, during discharging from 100-50% all is ok. After that SOC drops to 3% . Voltage is 54v on a 16s what is still good.
Thank you, Peter
Paul B avatar image
Paul B answered ·
check that the battery monitor you are using has the correct battery size set, if its a BMV or mutliplus/quattro unit - if its the batteries BMS being used as the batetry monitor then contact the battery supplier
