tom-donovan avatar image
tom-donovan asked
Can Ruvvi sensors be used to monitor and switch a heating system
I would like to know if it is possible to use the GX touch as an adjustable thermostat to control a heating system. I am aware that I can use a tanks sender to switch a relay a 2 designated resistance readings, so I could use this but then the customers heating would not be easily adjustable if he would like it a bit warmer in the evenings. I was wondering if anyone is aware if the Ruuvi units can be used as a thermostat so they switch a relay using a adjustable setting. I don't think this is possible, but I would be grateful if anyone knows a way of doing this through the GX touch and the Cerbo?
virtual switch
wkirby avatar image
wkirby answered ·
Yes, a relay which is set to the "Temperature" function can then have temperature control rules set up using a Ruuvi sensor as the source.
