shaneyake avatar image
shaneyake asked
Pylontech (MPPT) limited to 52.40V
Does anyone know why the MPPT is limiting the voltage to 52.40V?
It says limited due to BMS but BMS is reporting 58.4V as the limit.
Battery will not charge above 35%.
Thank you
MPPT SmartSolarBMS
shaneyake avatar image shaneyake commented ·
@mvader (Victron Energy) Is there anyway to remove the 52.40V limit and it follow the BMS voltage? I am happy to terminal in and edit files.
nickdb avatar image
nickdb answered ·
That's what pylons are limited to, so if you have a third party BMS spoofing a pylon you will be limited to that by DVCC. 58.4V definitely isn't a pylon so presumably some DIY/3rd party concoction off the compatibility list.
7 comments
Yeah, it is not a pylontech battery but is using pylon protocol. It is a 16S pack not 15S like the pylons.
nickdb avatar image nickdb ♦♦ shaneyake commented ·
Best (if you can) set it to spoof a different BMS on the support list.
shaneyake avatar image shaneyake nickdb ♦♦ commented ·
The battery is a black box, I unfortunately can't change any of it's settings.
Oops. Add a shunt and disconnect the BMS.
Once it identifies as a Pylon all the settings are forced on.
@nickdb you don't happen to know where this voltage limit setting happens to live? Is it in the CAN driver files?
Beyond my pay grade, but it is coded in. Can’t say if it is possible. Perhaps drop a post in modifications section?
Moved post to mods, hopefully a brainiac can help you.
shaneyake answered ·
I found the file.
"/opt/victronenergy/dbus-systemcalc-py/delegates/dvcc.py"
You can edit the file to increase the voltage. I have edited up to 58.00V and now I can change the DVCC menu to set the voltage I would like.
Thanks @nickdb for clarifying the cause.
Thomas Raabo avatar image Thomas Raabo commented ·
What did you change?
shaneyake avatar image shaneyake Thomas Raabo commented ·
You can simply remove the "0xB009: _pylontech_quirk," line or edit the _pylontech_quirk function to the correct voltage for your system.
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
