Hi there
I hope you're well.
I've got an un-usual challenge on A Multiplus-2 on its installation date as the installer switched it on, all 8 LEDs came on and it doesn't operate. What could be the issue?
Please find attached image.
Thank you
Hi there
I hope you're well.
Thank you
Probably the control board is fried. Can you 'discover' the inverter using a Mk2 / 3 and Victron connect?
If not, then the unit needs repair.
Thanks Mike for getting back to me, Yes we had it connected with a MK3-USB then connected to the computer and VE.Config did not find anything.
31 People are following this question.
