juan-perez avatar image
juan-perez asked
Connect a generator or electrical grid with the same Multiplus 2 configuration.
Hi
Is it possible to connect a grid or a generator with the same configuration in a Multiplus 2 as input? (not at the same time).
Context: In different periods I want to connect the electric grid or an external generator, without having to configure my multiplus, because I am not buying a GX device (I know that is possible to configure using the VRM access). I want to use only once an Interface MK3-USB.
My dc system will be always be fixed (PV and battery)
Multiplus-IIGeneratorgrid
Alexandra avatar image
Alexandra answered ·
@Juan Perezas
As long as you don't set a grid code (most do this to use ESS) you can have one that fits all. And it is the default feeding from DC to grid is not allowed.
Otherwise a grid code change requires a password.
xavier-64 avatar image
xavier-64 answered ·
Hello, I just update my system with the following @Kevin Windrem 's ExtTransferSwitch mod on @derrick thomas recommandation.
So In your case you will preset "the two case" you can have (on grid or on generator) without the need to manually setup them each time !
It works nicely !! You just need to do some pre-tuning with your GX (Cerbo or Venus) device and some command line !
Xavier.
iand avatar image
iand answered ·
You need to 100% guarantee that both AC sources can never be connected together, either with a manual break-before-make DPDT changeover switch or an ATS (automatic transfer switch) -- in which case you can use the setup described above.
