My friend is at sea and is getting this error per screenshot. I have checked the manual but see no ref to #24 Any idea what the issue is?
@John Rushworth I assume that there are LFP180 batteries connected to the Lynx Ion plus Shunt?
If so, there is a problem with the balancing, a battery is not receiving balance power by the CAN-bus cable(60V) or inside the battery a fuse is defect.
If the battery contains the latest software then a LED on the battery will start blinking 2 times.
- Blinking 2 times, there is a fuse defect;
- invers blinking 2 times, there is no balance power received by CAN-bus cable(60V)
(invers blinking: LED is constant on and go's off x times)
Thanks. They are the 180s here. https://www.victronenergy.com/upload/documents/Datasheet-Lithium-ion-and-Lynx-Ion-EN.pdf
I didn’t think there were LEDs on the battery itself but I shall pass the info on. Where did you find that info as the manual shows no error #24?
I have found this information from the source code, think this error has been implemented later on and is not updated in the manual.
Note, it's not an error but warning. This system will still be operating. Warnings are on my wishlist to implement but time en priority are the limits.
Thanks. Will pass on. They have now been sent a new shunt as it failed, so all working with the new one now. Firmware v2.03. Failed shunt was v1.25 as I recall.
5 People are following this question.
Lynx Shunt VE.Can installation
hey all, cant get ve bus to appear/be detected
LYNX VE.CAN-Shunt: Location of the configurable onboard relay
Will the Fuse LEDs on Lynx Distributor illuminate without the 4-pin cable supplied with unit?
Lynx Shunt VE.CAN Battery Status PGN for Batt Instance 0 not transmitted.
