hias0815 avatar image
hias0815 asked
Cerbo GX deleting or forget settings after reboot
i've a Cerbo GX did the Firmwareupdate from 2.89 to 2.91.
Set all my settings and doing a reboot. After the reboot all settings i've done are gone.
I noticed this kind of behavior also befor the update, sometimes (once a month f.e.) the Cerbo just "forgott" the settings and all where on default aggain.
Any suggestions?
Regards
Matthias
cerbo gxVenus OS
Benjamin avatar image
Benjamin answered ·
Try to check free space of your cerbo gx (SSH into cerbo and type df).
My /data partition was full and i had the same error as described above. It was not related to OS Version.
uarg avatar image
uarg answered ·
@Benjamin thank you very much. It was the data partition which was full with some logs. After deletion and reboot, everything works again.
4 comments
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ commented ·
Hey @Uarg , data partitions being full should be normal:
Were you running custom code, or guimods, or Venus OS Large, or something like that?
Or was it just a standard Cerbo with nothing special?
Benjamin avatar image Benjamin mvader (Victron Energy) ♦♦ commented ·
Same here. It was a Shelly Script logging to the partition like hell... Maybe victron could check the freespace and give a warning when it is getting full. Makes the finding much easier (in this case...)
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ Benjamin commented ·
Hey both, ok clear - thank you.
Good idea!.
uarg avatar image uarg mvader (Victron Energy) ♦♦ commented ·
Hello @mvader (Victron Energy) It was a simple pv inverter script fetching data from Solax. So my own fault and I could have figured it out myself. Hopefully this will help others. Perhaps a little disk usage warning would be nice.
Hi Matthias,
Thats not supposed to happen; and also not a known issue or problem.
Could you contact your dealer to get it replaced under warranty?
And please ask them to (as always) include a clear error description when making the RMA, include a link to this post on community and add that I asked for it to be returned for analysis.
Perhaps to make extra sure, please post the serial number here.
Sorry for the troubles!
Thanks! Matthijs
hias0815 answered ·
Hi Matthijs,
i alos made a small video of the behavior. Like you see, I switched back to 2.89 but now there is also this "bug" after reboot everything is lost.
Serialnumber of Cerbo: HQ2210926XW
I will return it via my dealer.
Regards Matthias
cerbo.mp4 (3.3 MiB)
uarg avatar image
uarg answered ·
was there a solution? I have the same Problem. I can change any setting, which will be lost after reboot.
Thank you
Markus
