123dyonisos avatar image
123dyonisos asked
Smart Solar MPPT 150/85 MC4 charging 12V, 24V, 36V but not 48V
Hi everyone!
I've got a 16S 48V LiFePo4 system with a Smart Solar MPPT 150/85 MC4. ~80V OCV with 4 ~300W panels.
Been having issues with the MPPT charging intermittently. I switched BMS a few times thinking that was the issue.
Now the MPPT is not charging more than 0-10W/0-0.1A while in Bulk. I've connected the MPPT directly to the battery pack (without BMS) for troubleshooting to eliminate any other issues.
The MPPT charges perfectly when:
- connected to another 12V battery
- connected to any 4 connected cells of the 16S LiFePo4 assembly (set to 12V)
- connected to any 8 connected cells of the 16S LiFePo4 assembly (set to 24V)
(only charging for very short time and same time to avoid imbalance ofc)
As soon as I connect it to all cells at 48V it stops working.
I've checked battery continuity, individual cell voltages, cell connector bars. PV strip continuty is perfect, been charging a Bluetti unit at 750W without issues.
I've scoured this forum and tried everything remotely applicable.
The MPPT is configured with standard LiFePo4 settings. Charger is on, jumper connected and ofc it charges at <48V.
Is it possible that only the MPPT 48V charging circuit broke? Am I missing something?
Thanks!
MPPT Controllerssmart solar charging behaviour48v battery
4 comments
What is the model # and serial # ??
123dyonisos avatar image 123dyonisos klim8skeptic ♦ commented ·
PN: SCC115085512
SN: HQ20297DPDP
SCC115085512 - SmartSolar MPPT 150/85-MC4 VE.Can (12/24)
This is a 12/24 volt (battery) model mppt. Not suitable for 48v battery systems.
The data sheet says 48V is fine.
I can set it to 48V and have charged at 48V before, it was just never reliable.
klim8skeptic answered ·
12 / 24 volt mppt's
123dyonisos avatar image 123dyonisos commented ·
Thanks! That is indeed very difficult to figure out.
MPPT Product Page
MPPT Error codes
