Can a Multiplus works like a grid tie inverter?
If yes, how can it be done?
Thanks in advance,
José.
Thanks in advance,
José.
With MPPT plus batteries it can, but indeed, the question is quite vague.
Ok, thanks for the answer.
By the way the multiplus II, is a inverter that can feed power back to the grid/loads working like a SMA or Fronius inverter, right?
Yes it can. It can do it with either ac or dc -coupled kit, or both. Call it ambidextrous. :)
What it isn't is a standalone pv inverter. Essentially it's a batt inverter that needs batts, but with everything else added/compatible. Powerful kit - get to know it better..
Nice :)
Yes, I also thing it's a great product. I already suggest to Victron that they should start to produce High voltage Inverters, that way they could reach a bigger market, because they have nice products, nice comunity, etc.
Actually Victron sold grid-tied PV inveters until around 2014. But they were too expensive compared to the (Chinese-made?) inverters of the competition.
Some suppliers still seem to sell old stock:
https://www.advitek.nl/merken/victron/victron-bluesolar-grid-connected-1500-converter.html
https://bluesolarenergy.co.za/victron-products/bluesolar-grid-inverter-5000/
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
7 People are following this question.
