Multiplia 48/5000/70 goes from ... ON at invertor to .... LED Float on charger side ?
Green LED (Inverter ON) to Orange LED (Charger Float)
I have a “Blue Power MultiPlus 48/5000/70 - Blue Solar Charge Controller – MPPT 150/35 - BMV 700 Battery Monitor.
My system worked without ANY problems from, 24 Nov’18, until, 5 Apr’19 (131 days), throughout one of the worst winters in Crete, Greece. Since the arrival of beautiful sunny weather, a problem started.
Green LED (Inverter ON) to Orange LED (Charger Float), since 5 Apr’19 until now 16 May’19 it has happened 8 times. Sometimes if I switch the Inverter OFF-ON it comes back on. Sometimes this solution takes Hours/Days.
P.S. I have NEVER connected my generator
Lowest Voltage = Zero, Highest Voltage = 58.2V
I have 4 x 200Ah batteries
I have nothing connected to the charger side ?
Hi @David Ohara
I'd contact your installer to check things out and if the unit is defective repair it.
Sounds normal.
What is the question?
System works ok ... then as I say ... goes from on at invertor to float at charger ... but no power ... everything off
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
9 People are following this question.
