xrtx avatar image
xrtx asked
Cable requirement Venus GX, MultiPlus and PylonTech US5000 Batteries
I'm hoping to get the technical specification for the cabling required to connect Pylontech batteries (US5000, in particular) and Venus GX with Multiplus attached. What are the connectors required at each end, please? I suspect the GX end is VE-CAN, but is there a different connector required for the PylonTech BMS end?
PylontechVenus GX - VGX
Alexandra avatar image
Alexandra answered ·
@xRTx
Instructions are here for Can cable.
Pin configs are here for the GX.
Leave pins 1to3 empty on the cable. It is stated explicitly in the Pylon manual to do so. And the cable kit comes with the pins 1-3 not connected so strong clies there.
The GX to the VE bus is a straight patch/UTP cable also outlined here in the manual.
xrtx avatar image xrtx commented ·
Many thanks!
