arie avatar image
arie asked
Ac Thor in off grid system using dvcc, will this work ?
Hello I have a great working off grid system sytem based on a easysolar 48v/3000 two pylontech us3000c batteries and 5Kwp solar. There is no solar on ac out. Only a dc charger (part of the easysolar)
The system is set to use dvcc. My question is : iff I use the frequency shifting function on ac out to regulate a ac thor on ac out ,will that work ? The ac thor will regulate a water boiler.
Especially considering the use of dvcc, I have read on this comunity sometimes problems ocure when using an ac thor in off grid instalations. These problems could then (partly) be solved by further ajustments of float voltage etc. In vdcc that (ajusting voltages) is not possible because the battery determines the voltage and current it gets. So do you think it will work ? Has anybody got this working ?
Hot Water Diversion
klim8skeptic avatar image klim8skeptic ā™¦ commented Ā·
Nevermind
0 Likes 0 Ā·
