gammatheta avatar image
gammatheta asked
accessing the programmable relay on a Multiplus (II) GX via the console
I’ve been through every menu option I can find on the console on the Multiplus (II) GX 48v 5kVA, all to no avail. Any pointers on how to access and programme the relay? I need to start a Hyundai Diesel generator when the SoC drops to 50%.
I’ve found settings for a ”Tank” but no relay.
Many thanks,
Andrew
Relay
ponzoa avatar image
ponzoa answered ·
In a Multiplus II GX, the GX part has no relays. You'll need to configure the Inverter relays using an assistant or Virtual Switch with VE Direct.
gammatheta avatar image gammatheta commented ·
Many thanks for your help ponzoa, I hadn’t realised that the functionality of the integrated GX card was so limited, I now wish I’d gone for the straight Multi and a separate GX device. I’ll take a look at the documentation on-line, many thanks again.
