Hi, I have a Multiplus 48/5000/70 (not multiplus II) - can somebody please tell me where the aux relay physically is? I can't see it anywher, starting to think that it's not fitted to this early model.
You should see it at the top right corner of the logic PCB.
The blue terminal block is pluggable if you want to remove it to access the entries more easily.
29 People are following this question.
