roel-buis avatar image
roel-buis asked
quatro 3phase
I want to use 3x quatro 24/ 5000 in 3 phase.
The generator is 27KW 3 phase
The grid is 64A single phase
Can i connect the grid to each unit to use all the chargers? (With 3 x 1 phase output)
(3 phase loads only to be used on generator)
Or is it still possible to get 3phase out the system with only the 1 phase input like some frequentie inverters do?
See drawing
3 phase
3-phase.pdf (26.9 KiB)
boekel avatar image
boekel answered ·
you can get 3 phase from one phase, but will have to connect only one Quattro to this single phase source.
Please note that in your drawing you connect all the Neutrals, please keep them seperate for 3x single phase operation.
For more information you'll have to tell what the use is and what other components are in the system (PV? ESS? Batteries? etc)
Also please consult an experienced installer for these big systems.
