Craig Allen avatar image
Quattro 24/5000 3 phase amperage vs single phase output?
I'm trying to find information on the 3 phase amperage output of the Quattro 24/5000. In single phase, single unit operation it will output 4000w at 230v = 17.3amps.
In 3 phase operation 3 will push out 12,000w (12kw). Is this 12,000/230vac or 12,000/400vac?
Is the circuit protection and cable rating for the wiring from the 3 unit cluster going to be 52amp (230vac) or 30amp (400vac)?
Any help is really appreciated.
3 phase
Phil Gavin avatar image
Phil Gavin answered ·
In a star- connected ( 4 wire) three phase system the phase current equals the line current.
So the same current value as if it was single phase for a 4 wire system.
(P = SQRT(3)*Vline * Iline for a three phase system).
Share
Boekel avatar image
Boekel answered ·
it's 12000/230/3
circuit protection and wiring depend on a lot of things, maximum input fusing is the rated throughput current.
But -please- consult an electrician (or Victron installer) for these kind of systems.
Share
Craig Allen answered ·
@Boekel thank you, will be getting it all verified, just trying to put together a bill of materials for budgeting and trying to understand what cabling and protection cost to estimate.
@Phil_Gavin thank you, makes sense.
Share
