Hello Everyone , I am wondering that Is it a good idea to have a battery balancer for lithium batteries on 48 volts system ? Thank you very much in advance.
If you are referring the Victron balancer, it is not designed for 48V systems.
If you have a 48V pack this should have one integrated internally as cell balancing is essential.
If you are talking about balancing 48V batteries then wiring is the best way to make sure each has equal charge and discharge currents.
How is this balancer not designed for 48v systems? Victron's own webpage on it says "A 48V battery bank can be balanced with three Battery Balancers."
Also, there is a Victron-provided wiring diagram for 48v systems
You are most correct. I did not think about use of the mutliple balancers on a 48v systen using 12v batteries. OP does not say they are 12v batteries being used in a 48V system however.
@Jasbir Rathor please review.
You did not mention what voltage your individual batteries actually are, however if they are 48v each individual then the origional answer about the balancer is correct, it cannot be used.
Apologies if I came across the wrong way. You are right that this of course would not work on, say, the 48v server rack batteries that are increasing in popularity these days.
Thank you Alex!
Alexander @Love2Learn ,
Thank you very much for the detail answered. Sorry for the confusion in my part that the question I had asked. I have lithium two sets of 48 Volts batteries. Each set has four 12 volts 300 amps. I made sure that each cable connection to the batteries and each connection from the batteries to the Lynx Power In are equal. Also I will make sure that all the batteries are fully charged before the system goes into the operation. System should be ready to go in a week or so. Thank you to all again.
43 People are following this question.
