joerg-winkel avatar image
joerg-winkel asked
Relais on Cerbo to control consumers under ESS?
(How) is it possible to switch Relais 1 on the Cerbo if the ESS is feeding into the grid, i.e. the battery is full _and_ there is excess PV power?
Would be handy to start e.g. the washing machine when the condition is met.
cerbo gxESS
Rob Duthie avatar image
Rob Duthie answered ·
Hi
Yes you can by loading in a software assistant you can do anything supply power to hot water cylinder, washing machine or what you like based on load current, PV excess etc.
Regards
Rob D
NZ
joerg-winkel answered ·
@Rob Duthie I suppose you mean loading the assistant onto the Multi and then use it's relay? I was looking for a solution to use with the Cerbo's relais...
Rob Duthie avatar image Rob Duthie commented ·
Hi
Yes you can.
lex33 avatar image
lex33 answered ·
oui mais comment ?
