jetstram61 avatar image
jetstram61 asked
40A Solar AC current sensor when used in parallel multiplus config.
Hi All,
Quick question regarding the 40A current sensor (measuring PV AC into L1).
When using 2 48/5000's in parallel, the ESS assistant is loaded onto both units after configuring them to work in parallel; however should the AC current sensor assistant also be loaded onto both or (I Guess) just the master unit into which it is connected ?
Just after a bit of clarity on this one - thanks
Multiplus-IIESSmultiplus in parallel
