rasti avatar image
rasti asked
victron alarm #27
I found this today in the VRM portal logs:
The victron error description says:
Err 27 - Charger short circuit
This condition indicates an over-current condition on the battery side. It can occur when a battery is attached to the unit using a contactor. Or in case the charger starts up without a battery connected but connected to an inverter that has a large input capacitance.
This error will auto-reset. If the error does not auto-reset disconnect the charge controller from all power-sources, wait 3 minutes, and power up again. If the error persists the charge controller is probably faulty.
I didn't stop the system, I didn't change anything, I didn't do anything at all.
Just saw the message.
The system was and still is running, so the error was auto-reset.
Should I be worried ?
Many greetings
Ralf
Multiplus-IIcharger
duncan-1 avatar image
duncan-1 answered ·
Hi I have the same problem..
Batteries are always connected at startup and not through a contactor, at this error, my unit just goes into Passthrough mode. nothing I can do in the settings or VRM will change this, have to turn it all off for 3 mins and then it comes back fine as if nothing has happened.
Duncan.
jodi5d avatar image
jodi5d answered ·
