reeltight4910 avatar image
reeltight4910 asked
Charging lifepro 4
Hi I'm new to victron and started to program the system. I have 3 300ah lifepo4 battries in parallel 12volt.(900ah total) I want to make sure I have the settings right for charging...I have the multiplus 2 and 1000amp lynx shunt ....the specs of the batteries are as follower. Voltage 12.8 charge voltage 14.2-14.6 charge current 100a per battery. For the 3 battries wired in parallel what are the safe/fastest charge settings to put in ..charge current? Absorbtion voltage? Float voltage? Repeated absorbtion time? Max absorbtion time?
Dvcc-max charge current ? Max charge voltage? Thabk you for your time. I just want to be 100% sure is all.
battery charging
nickdb avatar image
nickdb answered ·
You need to follow the guidance of the manufacturer. Supported batteries all have setup guides available:
https://www.victronenergy.com/live/battery_compatibility:start
I would encourage you to read all the docs and follow the training at:
http://professional.victronenergy.com
There is a good BMV tutorial also:
https://www.youtube.com/watch?v=mEN15Z_S4kE
reeltight4910 answered ·
Thanks for your response ll check into those..I listed above what the specs as far as charging the battries ..I would just like peace of mind for settings is all for recommendations, re my bank
Link to the battery?
