alda avatar image
alda asked
Victron and Home Assistant
I want implement my Victron system into Home Assistant.
I read a values via Modbus, but I'm really not sure which adress is for AC loads, Critical Loads and Total consumption, because values are not same as in VRM :
com.victronenergy.system PV - AC-coupled on output L1 808 uint16
com.victronenergy.system PV - AC-coupled on output L2 809 uint16
com.victronenergy.system PV - AC-coupled on output L3 810 uint16
com.victronenergy.system PV - AC-coupled on input L1 811 uint16
com.victronenergy.system PV - AC-coupled on input L2 812 uint16
com.victronenergy.system PV - AC-coupled on input L3 813 uint16
com.victronenergy.system PV - AC-coupled on generator L1 814 uint16
com.victronenergy.system PV - AC-coupled on generator L2 815 uint16
com.victronenergy.system PV - AC-coupled on generator L3 816 uint16
com.victronenergy.system AC Consumption L1 817 uint16
com.victronenergy.system AC Consumption L2 818 uint16
com.victronenergy.system AC Consumption L3 819 uint16
com.victronenergy.system Grid L1 820 int16
com.victronenergy.system Grid L2 821 int16
com.victronenergy.system Grid L3 822 int16
com.victronenergy.system Genset L1 823 int16
com.victronenergy.system Genset L2 824 int16
com.victronenergy.system Genset L3 825 int16
Thanks for help
victron
pau1phi11ips avatar image
pau1phi11ips answered ·
It might be easier to use MQTT instead of Modbus tbh.
