dsb avatar image
dsb asked
Cerbo GX not communicating with CAN BMS
Hi, All
I am trying to get a battery and Cerbo GX to communicate with each other through CAN-BMS, but it appears nothing is happening (im not too sure what should be showing but nothing changes). However if I connect the battery to VE.Can the solar controller disconnects so it appears something is happening. I have made a duplicate of the Victron VE.Can to CAN-bus cable and have tried the type A and B cables but still no luck in getting any information to appear.
MPPT 250 | 70 - MC4
Multiplus 24/5000/120
Cerbo GX
cerbo gxBMS
nickdb avatar image
nickdb answered ·
Which battery/bms is it? Just because it has a CAN port doesn't mean it will work.
Some also use straight cables.
The official list is here:
https://www.victronenergy.com/live/battery_compatibility:start
