manuc avatar image
manuc asked
connect an Emus BMS G1 on a Victron Cerbo GX
I saw in this post (https://community.victronenergy.com/questions/13574/list-of-compatible-bms-vebus-or-canbus.html?childToView=152821#answer-152821) that it is possible to connect an Emus BMS G1 on a Victron Cerbo GX system. I am in this case.I would like to know what the procedure is.
I have performed the following tasks :
- updated my firmware with version 2.9.2 file: EmusBMS_m1284p_v2.9.2_Victron.img
- connected the G1 BMS Control Unit to the BMS-can output of my Victron Cerbo GX via the CAN and - CAN + and GND outputs
Is there anything else to do so that the EMUS G1 is seen by the system Victron Cerbo GX system ? Because I do not see it ... Maybe it's my cable? Do you have a plan of the cable that needs to be made ?
Thanks for your help
Emmanuel
cerbo gxBMS
josh-laframboise avatar image josh-laframboise commented ·
hi did you ever get this issue resolved
