model3rider avatar image
model3rider asked
EM24 Ethernet regularly loses network connection
I have the EM24-E1-AV2 X version with LAN connection and the latest firmware X-1.1. Unfortunately, the meter loses the network connection every few days/weeks so that my ESS system (RaspberryPi 4 with Venus OS 2.89) has no data and switches off.
I have tested the EM24 with and without DHCP, both make no difference. There is a Fritz box in between and the data from the EM24 is only queried by the Venus ESS.
If the connection is lost, I have to deactivate and reactivate DHCP manually on the EM24, then it works immediately. Unfortunately only for a short time until the next failure.
Does anyone have a solution?
em24
gazza avatar image
gazza answered ·
Network/DHCP errors, particularly if they are random, are often difficult to pin down. I think the first thing I would do is try a different router to narrow down the possibilities?
gazza avatar image
gazza answered ·
I have just recently seen this thread as well that may be of use?
https://community.victronenergy.com/questions/66501/em24-ethernet-support-nightmare.html
