Can 2 autotransformers be used , 1 on each 240 output to provide split phase 120/240 on each from a single Quatro 48/240/15000?
I would be interested in this answer as well. Given the need to use a relay between the inverter and each Autotransformer, I'm curious what the answer is.
29 People are following this question.
3 Phase Isolation Transformer possible with Victron Isolation Transformers
Help look over Multiplus 2 schematic - Reward
Autotrasformer for US split phase and 15 kva Quattro
How many Victron Autotransformers can be connected to a single Multiplus II?
I have a 3000w 12v multiplus 2 , should I use an autotransformer to produce 240v for a mini split ?
