andrew2200 avatar image
andrew2200 asked
Centaur Charger not restarting charge
I have a Centaur 60A/12V which will not restart a charge when the battery voltage drops. I have to switch the charge on/off to restart the charge. Should the charger restart when the battery voltage drops as the manual says it can be connected permanently.
Thank you in advance
Andrew
battery charging
