Hello
I have just finished setting up my Multiplus 2 (5k) system with a 48V DIY Battery
I am running an up to date VenusOS and the current values from the energy meter are sent via MQTT from an external system (every second). On the Venus I am running a python script writing the values to the DBus.
The same is for the Solar inverter.
The current values also look fine - yet the historical data is totally wrong. I am not running a mining farm ;) - I am wondering if the VRM portal requires the L2 and L3 readings as well. I did not bother because I didn't see a reason.
The metering for the battery seems fine though - just the solar and power meter values are wrong.
