I have a 24V Victron system, When battery switch is off, smart solar and BMS remain energized with 20V in the system. Where is the 20v coming from if the battery power is off? BMS power connected to battery positive after switch.
Do you have a way to disconnect your PV as well? The MPPT can power up from that side as well.
Ideally you want to be able to isolate both incoming PV as well as the battery.
Someone told me that the 20v could be residual energy from inverter caps. I have 2 inverters connected in split phase 180. Is it possible?
Yes that is correct. Untill all the caps are discharged.
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
30 People are following this question.
Lithium Battery miniBMS / VE Bus BMS / BMS 12/200 - Low temperature protection available?
Integrating 123\SmartBMS with Victron components like the Multiplus and Smartsolar mppt?
Smart BMS Cl 12/100 Multiplus Compatibility
Internal vs External BMS pros and cons
schema aansluiting Orion- Tr Smart , Smart solar MPPT 75/15 , Small BMS Smart battery Protect65
